The questions are related to a unmodified '31 sedan. I rebuilt the engine 30+ yrs. ago. My recollection is that with the help of the local "A guy" we used two hard rubber grommets on either side of the chassis member instead of the standard springs and plate. These had holes in them and were mounted on the block yoke stud. The upper one between the yoke and chassis went south so the whole engine has settled and the crank wont fit into the radiator hole and then into the fan pulley. No other problems yet!. I loosened the mount yoke but there is not enough room to remove it. Is it possible to remove the fan pulley without having to replace the front seal? Any reasonable way with as little major work to replace this mount?? Help!!! Bruce
