I checked the Green Bible and found a picture if the 39 axle. This axle is what I have. OK the nuts on the end of the big bolts are removed, then the big bolts will hopefully come out and then the radius rods can be removed from the axle.
The 39 front axle came as part of the 35 coupe with hydraulic brakes on the backing plates.
Not sure what brake hydraulic system I will go with in the future ?
I will need new brake drums but not sure which ones.
Also prefer to run the 35 wire wheels.
Presently trying to gather the componets and then put together the chassis and frame members.
yeah pretty muchI was unaware that the 48 axle was different from the 42-47. Learn sumpin every day, till they throw dirt on ya.
So 34,000 lbs?! Holy crapUnless the perch bolts are so loose they rattle, you will need to do this in a press. I have a 25 ton press and most of those I have done let go at about 17 tons on the gauge. I always put a hardened nut on flush with the end of the perch to push against. Do NOT hammer on it, all you will do is mushroom the end and you will end up drilling or milling it out.
So 34,000 lbs?! Holy crap![]()
There’s also a replacement 32 to 36 axle that gets thicker / wider in the center …. I have one right now
