Bored&Stroked
FYI: Nowdays - one of the techniques to reduce friction and gain just a bit of HP is "low tension rings" - which are typically used with a vacuum pump to pull a positive vacuum in the engine (crankcase, valve covers, etc) and to reduce the amount of drag on the ring pack as well as the reciprocating assembly (oil mist, etc). Of course, most of these OHV/OHC engines are also running dry sump oiling systems - which also reduce drag.
Totalseal rings: On my recently ordered set of custom Ross pistons - 3 5/16 bore, I specified the 1.5, 1.5, 3.0 mm rings - which came from TotalSeal. This is the first time I've used this type of ring package in a Flathead Ford . . . so I'll report back how they work out and will do a leakdown at some point to really know. I'm finally going to start the engine in the next week or two . . . been waiting for this day for a long time!
