tubman
I am building a 258" (stock stroke, 3 5/16" bore) flathead. I had a bunch of stuff laying around, and when I had the opportunity to buy a set of pistons from Speedway's garage sale for a little over $100, I was able to procure the last major component I needed. I have everything gathered up, ready to go to the balancer. I have read several places that stock type four ring pistons can be run without the bottom rings to reduce weight and friction. As I remember hearing it, the old timers would save the unused bottom rings and install them in a subsequent rebuild for a cheap refresh. At my age, I doubt that I will put even 5K on this engine when finished. Is there any validity to this theory? I need to know before I send the components off to be balanced.
