sedanman36
Hi Guys
I read all the threads I could find and read my manual about replacing the core on the speedo cable. I pulled the core out, cleaned it real good. Inpected it and it is not twisted or broke.
The speedometer on the 55 was making noise and jumping around. I greased the lower 2/3 of the cable and tried to reinstall. Now the problem, I can't get it to seat back in the ******.
My manual says to just turn until it lines up and push it in. It feels like I get it started because it quits free turning, and then it won't go all the way. I tried for about an hour and gave up. Is there some trick you guys could pass on?
I was going to pull the cluster and oil the head as one of the posts said if greasing and cleaning the cable did not fix it. Will I have to take loose from the ****** end to get it in?
Thanks,
Sedanman36
Thanks,
Sedanman36
