Ford t5 adapter
You left a method out for an 8ba block.
Use a Chev bell housing by redrillling it to fit the block.
Then everything from the block back becomes Chev including the flywheel.
LOL, I could say I don't do Chevy parts! But I really just forgot. All I've messed with are the stock type clutch setups on the 59a blocks (mine is a 33). I really don't know much about the later block setups except what I read.
So you need to run the chebby wheel on the flathead?? how much doz that cost??
I get aluminum ones at swap meets for 125 to 175.
Takes about an hour to machine to fit the flathead.
This is consistently cheaper in the long run than buying a new aluminum wheel for a flathead.
I use scatter shield bell housings and usually pay 75 to 100 for them.
Another advantage here is they have more meat around the outer edge for
redrilling.
redrilling.
What starter do you end up using?
Sounds like allot of work, and I'd rather uz a cast iron flywheel for street.
Street people usually want to go the cheap route and this is cheaper.
I use a Chev gear drive starter. Mounts by drilling and tapping a couple holes.
Cast iron flywheels have been discussed (beat to death) before.
Not T-5, but something I did that others might find interresting.
It uses a Model Engineering (We are only 32, Gene Sanders) bell housing adapter to a Ford toploader transmission. This is a Jeep T-176 CASE ONLY with the Ford toploader gears installed. The Jeep shift housing is used.
Behind the trans is a small adapter that adds 2" to the overall length, that then couples a Gear Vendors overdrive.
I did all this because I wanted a 4 speed, an overdrive AND I wanted the shift lever right where Henry had it (within an inch, anyway).
This really works well, gives 8 forward speeds, if I want, and is controlled by a switch in the shift ball with the wires inside the shift lever. The lever is actually a Marlin Model 60 22 cal rifle barrel.
Thanks for the compliment, Bob
If I were going to do it again, I'd use the closed drive shaft and add the OD to the torque tube. It would be easier and quite a bit cheaper, I think.
Regards
Jim
Regards
Jim
Nice set-up. Would you use a Mitchell overdrive?
There would not be a reason to use a Gear Vendor setup with a T5. The GV provides the overdrive to transmissions that do not have OD. The T5 already has OD. GV will work on a lot of 4-speeds and automatics, my installation was behind a Ford C6 automatic. If you go to the GV site they have a lot of information about the setup and the applications.
Ol Ron
If you mean the bell adapter, I don't know if a T-5 will fit, but Gene also makes an adapter to use a T-5. Same setup as I used, I think.
Jim
