Allgaierfan
New member
Hi Model A specialists
I have since two month a model a roadster pickup of 1929 with the original engine. There i a Filterkit mounted from MACs. Part #: 28-24062-1
Its mounted to the timing gear cover. Does anyone know how does it work?
The copper line goes to the high pessure connected to the the oilpump where also the oil pressure gauge has to be connected.
But what happens with the pressure trough the Filter? Is there a pressure relief valve mounted in the filter? And if yes what max. pressure is installed?
if yes then makes a prssure Guge on same connector sense?
Macs doesnt answer this question.
kindly regards Robert
