I don't like that you can't save pictures off of ebay anymore. I did mine and they work great, I see how those clamp AROUND the bumper bracket. I used a piece of angle iron, drilled a hole for the shaft of the light, drilled a hole for a bolt (which I drilled through the bumper bracket) and added a external ground wire. One word of advice, if your going to go my route and drill through the bumper brackets use plenty of cutting fluid and go slow.......the brackets are like spring steel.
