Rainmaker Ron
Two questions, will a 32 four banger flywheel bolt up to a Model A engine with no modifications? What is the weight of the B flywheel?
Thanks, Rainmaker Ron
Yes the model B flywheel will bolt right up just like the model A flywheel and both use the same clutch. I put one on our roadster and it is 18 to 20 pounds lighter. it makes a noticable difference in throttle response and acceleration. It also helps gear shifting.
Purdy,
Help jog my memory here...was there something about needing to add/change a radius of the flange of the A crank if using a B flywheel?
I read something months ago...
Thanks!
Ron, the B flywheel is a direct interchange for the A FW. I don't know what the weight difference is but I can find out. I have one in the shop that has been cut and drilled for a V8 pressure plate. It is also balanced to +/- 1 gram.Two questions, will a 32 four banger flywheel bolt up to a Model A engine with no modifications? What is the weight of the B flywheel?
Yup what he saidHey Ron,
The B flywheel can be used on an A, but not versey-vicey.
The B flywheel is 12 pounds lighter than an A flywheel.
Model A an B Flywheel Details on Ford Garage.
Hey Ron,
Thanks Vince and all!
Sad news here at the Repo Depot, the G28 super banger we worked on at Bill Stipe's shop has developed a bit of tapping noise and I am taking it out of service. After 20,000 miles of 100 Horse power cruising I am reinstalling the original slightly warmed up engine. Somehow I let my light flywheel with V/8 clutch get away so I am happy to hear the "B" I have on hand will work. Thanks again for the help, stop by at Hershey.
Rainmaker Ron
