d.j. moordigian
Marco,
NO SHOT intended........thank you for the help!
I took some photos of an original and a repro a few years ago. I don't have a photo of the screw. I was also thinking of using a pipe or socket to give the correct form even though the size is a little different.
-DAN
Roy Nacewicz (www.fordbolts.com) offers a fine set of floorboard bolts and washers made to original Ford specs.
==============================I took some photos of an original and a repro a few years ago. I don't have a photo of the screw. I was also thinking of using a pipe or socket to give the correct form even though the size is a little different.
-DAN
Charles,
Where did you you find the #12 1 1/8" screws? It seems like most vendors sell 1 1/4" long screws. I have noticed that modern #12 screws have a slightly smaller head on them.
Rusty Nelson
Ok, I GOOFED on that one! I forgot that the early cars used A-9712 which has only the countersink portion and no outer flange. I think we mentioned it in Area-1 but didn't go look.
Can somebody tell me what page these washers are in Ford Model A Standard Hardware for nuts bolts and washers?
I just looked at my floor board washers and the original are flat, appear smaller OD with a larger screw head. The repop are larger OD and the screw heads are smaller. Later today I'll remove one of each and post a photo for comparison.
Note that in the last picture posted by Dennis directly above this post, the modern #12 head is smaller than the original #12 screw. I noticed this sometime back when I was replacing some dinged up screws in the hinges of my 29 pickup. The modern #12 screws sunk down inside the countersunk screw holes more than the original screws. Maybe Dennis can mic the diameter of the original screw heads and the modern screw heads, as it looks like he has a mic available. I am wondering if the original #12 heads are more like 1/4" flathead machine screw heads in size.
Rusty Nelson
Dudley & Charles, Thanks for the photos and the ideas on making the repro's look more like the originals. Since the repro's aren't really the same size as the originals, that's probably the closest to the shape that can be done, but they're better than just flat, the way the come from the suppliers.
Dennis, nice photos and comparison of original and repro. It's interesting to see the screws inserted into the washers, there's quite a difference.
I don't want to start that discussion again, but holy cow, this shouldn't be a difficult piece to reproduce correctly.
More pictures? No problem. One of the POs painted the interior floor with black paint because they didn't know any better so ignore the black paint on the original washer, I hadn't scraped it off yet.![]()
