Gold Digger
Can anyone tell me where to buy what ever the material is that used for glass on roadsters. Mine is getting to where I can't see through it. The rest of the top and sides are perfect.
Brent covered the glass but if you are talking about the see through plastic that is sewn into the rear of the roadster pickup top (I think roadsters should be glass but check the judging standards, maybe standard roadsters were sewn in plastic) I would try a top shop that installs convertible tops on late model cars. With luck they will give you a scrap big enough for your window. You should ask what they would charge to sew it in.
Charlie Stephens
Brent,Great point as I forgot he had a '30 Roadster Pick-up. Thanks for pointing that out.
