I had the same problem with the speedway kit ,not a big deal .JMOI just completed the AOD to 8BA install, using Speedway's kit. This is my 2nd use of this kit, and it went well EXCEPT the instructions are not too clear and complete. For example, you need to use 2 block plates to get the starter snout back far enough to clear the flex plate. On the prior install I made a spacer out of .060 aluminum to use with the block plate. All in all, it's a good kit.
