There is always an electric fuel pump.
just looked down the hole ..the bearing is to far rearward by about a10th of an inch.do you think i can pull the trans and flywheel get to the rear cover and press it in ?
it has been verified ,,the bearing is to far foward by about a 10th of an inch
Ok, missed that! I still vote for the electric fuel pump.![]()
i think so , i can see the edge of the bearing .it wont allow the rod to drop down contact the cam lobe ..As 40 said....its best to verify where the bearing actually is, and I'm also wondering if it's the bearing that's actually preventing the fuel pump pushrod from moving up and down in the first?
Does the rod go in but is a tight fit?
