40cpe
hey don't like just jumping in here, quest on your response george, yep have a red and black lead on meter.. you mention place red wire in coil, you mean in the hole for the plug wire from distrib? thanks again...
PM sent
40cpe has it right. Jump from hot side of battery to coil + post and bypass ignition switch. It's quick and easy. If it starts, it tells you where the problem is.
So.......if it starts what would that indicate? That there is something wrong between the coil and the start switch? I have a similar problem and not sure whether I have the right wires on the right posts on the coil.![]()
