I like the Max #1 as well. however, thought of paying 500 bucks to install one now, gets a second thought. Might as well get something better for your money. Trouble is the definitions of "Better". Plan ahead!
I just grabbed this from the HAMB.
"krylon32 said: ↑
What's wrong? I can't believe you HAMB guys don't have both the experience and an opinion on this."
Yes, everyone has an opinion. A few have experience. Although the info has been posted many times on here, I guess another time won't take up too much bandwidth.
A 400jr is a VERY poor choice for a street engine that is expected to live a long time.
It has very poor velocity and jerk numbers for longevity. It is a race grind.
Most of Isky mild grinds will live a long time. Some idle stock smooth, others have a slight lope which some people desire. The only way to experience what a certain cam is like is to find a car with one in it and see if you can drive it.
Even that is not too good because their engine may not be similar to what you plan. Most people choose too much cam for the type of driving they intend to do. You can make a stock cam have that drive-in rump rump idle just by tweeking the idle screws and it far cheaper.
There are certain cam grinds that you hear about all the time. Why is this you ask? It is because tomorrow no one remembers second place. Consistent winners are the ones you hear about most.
A cam can have fairly aggressive lift curve numbers but still be a good street grind if the numbers are applied right.
There are some that are right and quite a few that are way wrong.
I ran a 400jr in a 41 coupe 3/8 x 3/8 motor, slightly larger than OP's but close. I used stock springs and ran two 97's with direct linkage. Stock springs were easy on the cam and I did not need to wind it up like a race engine. Performance was strong no hesitation or flat spots, pulled real good low to high. I guess that puts me in the minority.![]()
My engine was built before I bought the car but I got a spec sheet with the car. I wonder if one of the cam gurus could rate the cam: 8ba bore 3-5/16 stroke 4-1/8 stainless valves, balanced lightened flywheel..cam Schneider, valve lift .375, duration 264, lash .012 -.012 adjustable lifters. Offy heads & dual Holly 94s, 10" clutch. Seems to have lots of pull throughout the rpm range
(I havent gone above abt 4k rpm.) I cant find a cam with these numbers on the Schneider site. Is this a good overall setup?
In going back through the Schneider cams, mine comes close to the P-3/8.
Anybody had experience with this cam?
Interesting numbers here. The cam in my 280 is an EAB. I used it because everybody said it was a good street cam ....
Gramps
