I'm sure I'm not the first with this problem. Maybe someone out there can offer a solution. Left hand header won't clear steering box. 59A into 37. Wary of grinding header, as casting only looks to be about 3/8" thick at critical spot. Ditto concern re grinding steering box. My solution is loosen anti-rattle rods, re-drill water pump mounting holes on cross member about an inch to the right, trim one side of right rubber biscuit to fit, re-install mounting bolts and re-tighten rods. Any pros or cons, or better ideas? Thanks, for your ideas. Help most appreciated.
