glennpm
"The most restrictive part in the whole coolant system is probably the thermostats themselves, so not entirely sure if I’ll ever add them back. I will never operate this engine at anything close to below freezing temps so not sure if they’re really necessary."
Yes, probably but when you have more time on the motor, you may find the radiator is cooling too much. You could also spend some more money and use a butterfly or ball valve to restrict flow although thermostats aren't all the bas. They're like having an orifice plate in the pipe. I used to do all this piping, valves and pressure vessels for a living on power plants and refineries
I over bought the radiator in my '32. It ran a little hot for a few miles as I mentioned. Now I have a poor man's winter front where I can control airflow through it. Works good.
Re. Tubman's comment, "My advice is to start looking deeper if you can't get it cleared up right away. Don't just plow ahead."
You can get a decent infrared thermometer from Harbor Freight that works well. Check each of the exhaust runners and the adjacent block. It could identify a local issue.
Regarding the snow machine, I had an awful time getting my Toro lawnmower going this week. I don't give up, and tried everything I could and pulled it 100 times at least. It runs like a champ now and I think it may have been an adjustment of the governor, fast idle speed screw and a vacuum hose fitting, that were to blame. All hoses replaced, new plug and electronic module, new carb but put old one back in. About $25 for all parts and it's good as new now and all set for Spring!
Glenn
Glenn
Glenn
Glenn
