Fender Installation
Brent, the bracket in your pic is straighter than mine. Mine has a curve along it's entire length. It might work if I moved to the rear hole, as you note, but the hole spacing would be off and I would have to redrill the bracket. Should the Coupes have two holes or three at this location?
Is your car registered 30 and is a 29 transition sold in 1930? Could it be a modified front brace hence the curve? or an early A bracket?
I just went through this on a 30 Coupe. I had to reshape the brkt. to make it fit. And make a 1/4" spacer to go to the outer edge of the fender. I hate A/m parts more and more. I was working on a 1967 Camaro for a guy and got so frustrated working with A/M parts I had to stop before I wrecked something!!! and I've been working on cars for 45 years!!
