does the felt pad go between the boards and the plate or between the plate and the mat? Thanks
Could I have installed mine incorrectly, or have a defective felt? Seems like in only a few weeks the openings expanded and/or the pad shifted, causing it be virtually worthless for sealing out dirt and air.
My system works just fine. Felt pad, then metal plates, then rubber floor mat, then large bath towel wrapped around the steering column. Remove the towel in the summer because the air coming in around the steering column is cooler that the air coming in off the manifold/muffler on the passenger side.
W. Michael
We will be making a very nice rubber seal to go around the column in that location. they will available soon. He is making the mold next week.
Steve @ Berts
Steve @ Berts
How about making something that fits on the pedal shafts, under the floor, that plugs the holes up when the pedals are in the up position?
X 1,000 that. It is VERY uncomfortable driving a Model A in the summer with the heat from the exhaust coming up around the pedals. I've even considered clamping something to the pedal shafts that would seal against the under side of the toe board but there is soooo little clearance between the block and exhaust flange that they wouldn't work. (That's where the clutch pedal goes)
