felt pedal pad
We will be making a very nice rubber seal to go around the column in that location. they will available soon. He is making the mold next week.
Steve @ Berts
Steve, is it the full pad you are making with slots for the pedals, or just a collar for the column?
Synchro, I've never seen a RHD car. Are you sitting over the muffler? Or is everything just flip flopped to the opposite side. Is your motor different?
Tom, Not much room on the "drivers side on a RHD car... :p:p Easy to get to the starter tho.
Could I have installed mine incorrectly, or have a defective felt? Seems like in only a few weeks the openings expanded and/or the pad shifted, causing it be virtually worthless for sealing out dirt and air.
I made my own, using carpet padding. I made the holes smaller and the pad oversized, so it did not shrink with use.
When that TALL SHAG Carpet was the RAGE, folks cut a BIG rug that covered EVERYTHING. Made it COZY & very QUIET!
Better than the COLD LILLOLEUM Chief used. He even used it for DOOR PANELS! It wuz GREEN/BLACK & COLD to lean on!
CAR BLANKETS were "standard" equipment.
Bill Shivering
