I have a truck F150 transmission, drive shaft, tube and radius bars for sell asking
$2100
$2100
Well folks if you have any leads on the 22t input for the "Goldilocks" transmission please let me know. Think I have everything or a path to everything I need for the build!
22T
D8UZ-7017-B
2603806
T170-16G
8-7/8" long
Thanks to all that have helped. Should have the OD gear from the machine shop this week and have started assembling the "Goldilocks". Sure I will have lots more questions.![]()
Does anyone have a lead on an output shaft for this transmission?
I have an output shaft for the T170 for sale if you are still looking for one, etc.
Also the T5 has too low of a 1st gear and only provides over drive in the high teens vs. the Ford's 23 or 28 percnet.
???? Why would the front wishbone break with the f150 trans change ?Did I miss something in this thread? What about the front wishbone breaking?
Since the Mitchel trans and OD unit have lifetime waits, I have been reading old posts regarding other transmission swaps. The comments about the T5 having a too low 1st and a minimal OD ratio makes me wonder about the differential gears. Are these comments based on a 3.78 rear end? Would a 3.54 gear set improve the drivability of a T5?
It stresses them, and they then to break.
I think theres some confusion on your part, you might be thinking of the REAR radius rods when using an open driveline. Forcing some to self-engineer ways to locate the rear axle with the now missing torque tube
The front wishbone on my 31 CCPU mounts to the bottom of the AA bellhousing just like it did when Ford made it only with the A housing.
Where is this mysterious stress coming from ?
