nichols617
Before I take off the clean out round plate on the oil pan, is there a gasket there? It looks like it but can't tell if it's copper or felt. What am I getting into? Any tricks/
Thanks,
Stu
Thanks,
Stu
the plate and outside gasket will come off ,not sure if the ring with the bolts in will pull through the hole ,as I said I did mine with the pan off,if you don't disturb the inner ring and gasket it should all pull together o.k ,put some goo on the new outer gasket , cheers jim.I plan to remove the clean out plate/cover when I change the oil and not remove the pan. Can I do this from under the truck?
Thanks,
