Has anyone found a rubber (or otherwise) line that will withstand our new and improved gasoline ? I'm referring to the short pieces most of us use when splicing an electric fuel pump into the line. I've gone thru several of the flex lines from firewall to fuel pump, but the biggest problem has been the short pieces used splicing in the electric pump.--turns them all to mush. Someone must have found a solution by now. Thanks--JR
