Terry NJ
Deck Height is 1/32 over the deck! Yeah I know, It's crazy but that's what it is. For breaking loose. Try ATF and acetone, 50/50.Or MMO (Marvel's Mystery Oil). But unless I'm wrong, Your real problems are going to be with the valves. While you're messing with the pistons, Put some of your "Deruster" down the valves, I hate to give you the bad news, but when an engine sits for the length of time this one did, it rusts internally, Cam and lifter faces. Best to save yourself a lot of crawling underneath and pull it. It will go a lot faster. Clean all the scale rust of the parts. That scale rust will break off and go into your oil like so much sand and grit.
Terry
Terry
