foxfire42
My A won't start! Well, it actually won't turn over so naturally it can't start unless it at least does that. It has a battery disconnect on it . At first I thought I forgot to turn the disconnect on but it's was on. Following is what I checked or tried not necessarily in this order.
1. Changed the starter switch as the rod and switch tube did not line up and caused the rod to bind on the firewall causing it not to engage the starter switch with my weak old lady legs. Still won't turn over!
2. Checked the battery charge. (6.27V) So checked to make sure the battery switch was not defective. Measured 6.27V at the starter switch.
3. I removed the battery cables from the one in the car, hooked up my spare battery directly to the starter switch and ground on the engine.
I know that the battery cable could be the problem thus I went direct. The starter made a groan and that was all.
4. Removed and bench tested the starter. WORKS GREAT.
5. While it was off I used the crank and manually turned the engine over with ease.
6. Two starters, two starter switches, two batteries and various ideas were tried. I wired up two 6V batteries in parallel and was able to get a slow motion engine turn over. Although the parallel 6V batteries don't change the voltage it does double the amperage. Both my batteries are rated 640CCA and 800CA. My last try and failure was with the 1600CA I didn't have my big charger with the Engine Start feature to try that.
I rarely give up but I'm getting close on this one. What am I overlooking?
I once had a starting problem on a tour and found the positive ground cable from the battery was frayed. Held the pieces together with a vise grip and finished the tour. I hope this problem is simple like that was but if it is I won't be embarrassed just disappointed I didn't fix it and had to ask for help.
