Pshhh...
If you want good and cheap, I got the solution.
I just had a piece of right angle stock, 10 gauge, and drilled 3/8 I believe holes 3 inches on center away from each other on one side. The oil pan bolts can be taken out from the bottom and threaded through the top and your holes.
Then you just need two holes drilled on the other side; mine were 1/2 and they are for the engine to mount to your stand. Everything just bolts up then using your cheap harbor fright equipment.
