I am going to spend pennies instead of $90+ for an engine stand adapter for the Model A engine.
I have gone thru the achieves and found many pictures illustrating many variations of the adapter that bolts to the water inlet with pins thru two of the oil pan holes.
The pictures give me many ideas to choose from, but there are no dimensions. I am especially interested in the dimension where the pipe is offset to compensate for weight when the flywheel and housing are mounted.
Does anyone have a drawing with dimensions? While I can measure the dimensions for the bolts and pins placement; I would like the offset dimension.
Thanks
Thanks
