some one on a post higher up ask, what oil to run, is run any oil you want as long as its detergent oil, the only manufactors i know of that says use non detergent is air compressors for the hobbiest, and i dont even use it in mine, my compressor is 17 yrs old and still works perfect, and another note, dont use the oil that has the red circle on the container that says for gasolene engines only, it contains little or no zinc to proctect the cam and lifters, that oil is meant for the new engines with roller tappet cams and lifters and they dont need the zinc
