The plugs are not new but I did clean them and regap them and they do show spark when the engine is cranking. I have been told that the engine does not require a lot of choking however when I do get the engine to catch and run for a few seconds the application of the choke half way open helps keep the engine running longer.
Thanks for all the responses. I believe I am getting fuel as I have checked for restrictions. I did learn the starting method by watching a YouTube video. It agrees with what you described and I believe I am executing it as described.
I have a timing light but I am not sure how to use it on a Model A. Can you elaborate on the method I should use for using the timing light.
I am not sure what you mean by the term "IMHO"
Thanks for the help!
Bob
Ok Bob, I was the poster of the thread mentioned above about our A not running just like what you have mentioned. I have tried everything for weeks to get the thing running. I ended up taking it back to our rebuilder and he took the spark plug leads off the distributor and cranked it over and success it started right up. Our rebuilt carb was the issue. For some reason it was always running rich even when the adjustment was turned off and it was fouling our plugs. Not 1 but all 4 at the same time. Here is a video of it starting with the spark plug leads off. Try this and see if she will run!!!! It sure shocked me and I was lost for words. Just because it was rebuilt doesn't mean it was rebuilt right or working right. Give it a try and let me know! Before trying this take your plugs out and make sure they are dry and clean.
http://www.youtube.com/user/bogdonavich#p/u/3/NquVJtQCOo4 --Video
My post regarding NO START
http://fordbarn.com/forum/showthread.php?t=16974
Justin
Pat
After posting as a Newbie and receiveing the recommendation to get involved in a Model A Club I went on line and got the information and I am going to attend my first Model A meeting this coming Tuesday.
Thanks
Bob
I spent most of the afternoon trying to get the A to run with little success. I retimed it and toward the end or the day I noticed that the spark at the plugs is intermitent. It appears that when I first turn the engine ove I have spark but within a few seconds the spark disappears. Does that sound possible?
If I chose to by a new coil do i have to get one specific to the Model A or is a 6 volt coil a six volt coil.
Bob
Also take a jumper wire, remove the instument panel screws, and jump across the ignition switch if it's a repro. See if that doesn't help.
