It came with the car which I purchased in 1970.
Why the other end not fit my wheel lugs ??? The tire wrench
End is smaller.
Fredski
Jeez, ...this one could be all over the place. Do you have the correct size lug nuts? Can you post a picture of the crank along with a measurement of the inside of the lug nut area of the crank so we can help you?
Same as Bob, I wonder if you don't have the hard to find early hand crank? If you do, you are lucky because they are much more rare than the common later crank.
