Purchased 1929 Murray Town Sedan 2008. Engine has performed fine without any issues. This year I noticed weeping at head gasket with radiator spray going uphills. Began the work to change head gasket.
for the first time I noticed the stud at No 1 is not like the rest - is a 3½in - 1/2in N13 bolt with washer. Once head removed I could see the No.1 hole in the head was tapped for 1/2in N13 threads. The No.1 stud location in the engine block also tapped for same bolt going into the water jacket. I seemed to have gotten away with this shade tree application the past 17 years.
Yikes. What did I get myself into? Do I simply replace the 1/2in bolt with a new one or is it time to do this correctly if even possible? Any advice would be appreciated.
