I'm attempting to complete installation of emergency brakes on '29 Roadster. Can someone confirm what the proper rod length should be from the Emergency Handle to Cross Shaft.
The car came with a right side mounted handle and 20-3/4" rod mounted to the cross shaft (yoke one end). There were no emergency brake rods or shoes when I purchased the car.
I've installed shoes and standard 41-1/2" brake rods. With the clevis on the brake rod screwed all the way in (bottomed out), it appears rods are about 1" too long, or the cross shaft to handle rod is too long (incorrect one was on the car).
I've noticed in Mike's catalogue, that in addition to the 20-3/4" rod (yoke one end), there is also a 18-3/4" rod (yoked both ends), both listed for 1929. Before I source a 18-3/4" rod, I'd like confirmation that this is the proper rod for the '29 roadster.
Thanks in advance for any guidance. I'm a newbie, just learning the ropes.
