42merc
Just saw this so here goes, No. 1 edelbrock does not make these Dennis Carpenter does, a friend of mine put 8, yes 8 on a468 ci small Block and they run great. I just put three on a 48 coupe I just finished and they are good but the stock 260 hp crate motor wants them leaned out more but they run good now. The throttle works great using a cable a rod would also work, and using a kick down for the 200r trans. If you havn, tried them then hold your negative comments. We have sold several with not one return.
You are talking apples & oranges.
The Carpenter version is direct copy of the 94 using the 8ba mid section with different tops & bases to fit the trucks & cars, early or late. I believe they are cast offshore.
The E'brock carb is their version of the 94. They supply different bolt on throttle levers to accomidate original Ford & other configurations.
I believe Edelbrock casts these in the US.
