Dwell Angle
I used the B cams in both my cars purchased from brattons / swapped out the A cams... Very high quality and a noticeable improvement as well
Are you speaking about camshaft or cam in the distributor?
If distributor do have to modify b cam to fit.
Not understanding this quite.
Fred
Fred
The cam in the distributor:::: no modification needed:::::but do a timing and point gap reset after installation
A dial indicator setup on the back of the points is rhe most accurate way to set them. You can also check the variation in the cam lobes.
