Hotrodvideo
What dual master cylinder can I use that is close in bore size to the original flathead single res?
I made the conversion to a dual M/C using a '69 Mustang unit 1" bore. Brake performance improved greatly with the existing setup. That was '46-'47 fronts and '40 rears. I still was not satified with the pedal travel. The pedal firmed up about 1" off the floor. I ended up using a Chevy/GMC C20 M/C 1.125" Bore. That is the same bore as the original. The pedal is back up where it should be, about 1.5" from the top. I ended up installing a disc kit from Speedway. I am now satisfied with the stopping performance.
