Whatever is causing it to lock, when you discover the cause, please let me know so I can modify mine to do that. So many times I tell the spouse unit to lock the car and she doesn't. That automatic locking feature is exactly what mine needs.
They’re tough to get in if you get locked out!
So if the passengers is locked and you don’t know it….and the ignition key isn’t the door key…..often
No remote!!
The little bump on the plate that the spring goes around can get worn. I haven’t had to do it but a shot of weld material on that would fix it.My S/W also does this sometimes. It's 100% momentum.
I leave the window open so that I can reach in from outside and push the inside handle down to get it out of the Locked position.
This is annoying. I replaced the flat spring on the remote a few years ago (PITA) and it fixed it for a while, but now it's doing it again. I think there is wear on the remote and the spring pressure is not enough to keep the handle from jumping up into the Locked position.
Leave the window open.
