I have a 25 Tudor with wood doors. Does anyone know the factory procedure for installing the glass channels and glass. The channel brackets were bent at the top to help remove the glass but I am sure the factory did not install them this way. Also the original glass is 9/32" thick. With the aftermarket channels this looks like I am heading for problems. If I have replacement glass made what thickness should I use and should I retain the original dimensions or should I have the glass cut narrower on the vertical sides, If so how much.
Thanks Daren
Thanks Daren
