Jwawhite
Something doesn't add up.
The Dome Light (DL) is Grounded so when the DL switch is moved to the On position, the light comes on. A hot wire comes from the Head Lamp Switch for power. OK
The Plasticized Diagram also reads:
A Second wire from the DL is mounted before the switch so it's always Hot regardless of the switch on the DL. This wire is sent to the Drivers Door switch which is just a simple on/off.
Two wires are sent over to the Passenger side Door Switch.
What good does it do to open either door??
How are yours wired??
