When it get below 35* the roads are white with salt, and I don't drive on salt.
Its called Halon 1211. It is carried aboard aircraft because it is non corrosive and less harmful if you have to discharge it in a relatively enclosed area. That would be my choice for the Model A also.
http://www.h3rcleanagents.com/support_faq_2.htm
Appparently there is a less expensive substiture for HALON 1211 called HALOTRON as shown in this link. Any experience from the Fourm on this item which is $100 less er unit and claims to be as good as HALON 1211?
Thanks
http://www.webstaurantstore.com/buc...ogleShopping&gclid=CMHdgbHt_8MCFUnl7AodeyAAFw
We don't need no stinkin fire extinguisher.
A hot rod living up to it's name.
That would not have happened if he drove with....whitewalls!!!![]()
I wonder what oil he used.
Depends on whether your wife is with you or not.What other things are "must haves" in your car? (not counting tools, jumper cables and lawn chairs)
Does anyone use a Tundra Fire Extinguisher?
