Distributor Shaft Sleeve
DBSHELTON
I need to re-install the Shaft Sleeves on a couple of Distributors I took apart and rebuilt. Would it be OK if I used 1/8" dia Roll Pins instead of 1/8" solid pins?
Sounds good to me. I believe the new sleeves you would get from the vendors come with a roll pin instead of solid as well.
