D DBSHELTON Senior Member May 25, 2020 #1 I need to re-install the Shaft Sleeves on a couple of Distributors I took apart and rebuilt. Would it be OK if I used 1/8" dia Roll Pins instead of 1/8" solid pins?
chrs1961815 Well-known member May 25, 2020 #2 Yes it is fine as long as it is thr right length and holds it tight.
ryanheacox Well-known member May 25, 2020 #4 Sounds good to me. I believe the new sleeves you would get from the vendors come with a roll pin instead of solid as well.
D DBSHELTON Senior Member May 25, 2020 #5 I just put 2 together and everything is tight. Used the same roll pins as small block and big block Fords use.
