Bassman/NZ
1* C59A 42-48.... is the single piece crab style distributor cap interchangable with the two piece cap set?
2* If so, is the same rotor used for both?
3* How about the spring clip that holds the cap on?
4* Is there meant to be a seal or gasket between the cap and the distributor body?
so many questions... so little time....
