Neshkoro
I pulled the head on my Model A to install a new head gasket.. My. distributor has a 2 piece shaft. I thought the top surface of the lower shaft was about even with the top surface of the block but now that Im reassembling things it seems the lower shaft is about a half inch above the block surface. Am i wrong? I can't seem to remember how it was when i pulled the head. Can you tell me if the shaft should be flush with the block head surface or higher than that?
Thanks.
Thanks.
