Hi all, Distributor cable won't tap into the new distributor, suggestions?
Is it always a project to get it in there?
Thanks!
Thanks!
Why should you not screw the cable fully into the distributor? I screwed mine in as far as it will go using a vice-grip spanner. I did it about 100 miles ago and have had no problem yet. Should I expect something to go wrong?
The center of the cable pushes against a plate in the distributor. It can be pushed so far as to push it against the body and cause a short.
