Ordered the Coil from Dennis Carpenter should have it today
Do have question on Plugs?? Should probable start a new thread but any suggestions for spark plugs would be appreciated Have the standard Champion H10
's in the engine currently (I'm pretty sure )
John, how do I ask for the correct rated diode? amps, watts, etc.
Thanks, Gene
ok tried it again no dice I'm beginning to question weather these NAPA points should be set the same as factory. I did look real close at the shaft and I also coated it with 3M liquid tape in the center however I have fairly convinced myseld that it has something to do with the points. Stay tuned once I find the solution I will let you guys know
