Robert/Texas
"backfires misses, when the pedal is pressed down hard"
Accelerator pump in carb?
OK second verse,,I bought a new filter and gas in a clean can. Set it up above engine, started the engine and it does the same thing, backfires misses, when the pedal is pressed down hard. Not the gas, but the tank is dirty and I'll clean it. I just got my dist. back from Bubbas and the coil from Skip. Skip didn't say anything about the condensor so I figured it to be OK. Now I'm thinking ignition because the new gas does the same as before I sent them out to be fixed. There goes the rest of my hair. Could it be timing, kinda sounds like it. The spark plugs fire but look weak sparking, only 1/16th spark to block.
Thanks again for the replies, got tank washed out and it has been coated before. Has a grey color to it and can see where it's built up in places. Don't think it can be recoated over the old sealer. Anyone ever run in to this problem. Al
