Purdy Swoft Well-known member Aug 17, 2019 #3 The correct timing mark on the crank gear is right at the keyway .
1955cj5 Well-known member Aug 17, 2019 #4 "The correct timing mark on the crank gear is right at the keyway ." Here is a picture..Model A engine. Attachments 2015_0814modelajeep1489.jpg 71.3 KB · Views: 67 Last edited: Aug 17, 2019
Joe K Well-known member Aug 17, 2019 #5 The one crankshaft gear I can get to quickly shows the match dimple in the same "offset from the key" location as shown in the pix. The one timing gear I can get to quickly shows the timing dimple in the same "offset from the two alignment holes" location. What's not to love? And are you seeing yet another timing or match dimple that I don't see? Joe K
