crank gear
"The correct timing mark on the crank gear is right at the keyway ."
Here is a picture..Model A engine.
The one crankshaft gear I can get to quickly shows the match dimple in the same "offset from the key" location as shown in the pix.
The one timing gear I can get to quickly shows the timing dimple in the same "offset from the two alignment holes" location.
What's not to love? And are you seeing yet another timing or match dimple that I don't see?
Joe K
