Cracked babbitt
Thanks James. There was no tinning in the bit I levered out as you say. The folded-out tinned piece next to it was a fight to detatch with hammer and chisel.
No 3 piston was too tight but may have survived if timing had not been so retarded when an "expert" altered it at 4000 miles and I took it back to my shop before checking it. It nipped up before I got there. It had run 4000 miles with no problem before this event killed it.
Thanks for your comments.
Off to bed now- its midnight here.
SAJ in N Z
SAJ,
Are you running a fuel pump with this engine setup?
From your post #18 above I can say most likely that you are not using a fuel pump.
I have been using B carbs on A and B engines for 50 years.
I always had lean mixture problems with them Using the:
1. "head with a large B" (Most use is with this head starting in 1963.)
2. 6.5 Lion head,
3. Thomas 8.5
4. stock heads.
I finally stopped using B Carbs for a long time.
I had to run the GAV at 1/2 to 2/3 or more but it still had all the signs of being a lean mixture which my Exhaust Gas Analyzer confirmed.
Then some years ago I found an answer to the problem.
Here is an Ahooga post from 2010 of what I found:
Benson
08-08-2010 08:28 AM​
Does your Model B carb-run bad with GAV closed?
This was discussed last month on FB ... so it may be of interest to some.
I have had trouble for a long time with a B carb on my Model B engine that will not run right with the GAV closed.
It must be 1/2 to 2/3 turn open (it is better but still not right with GAV 1/2 to 2/3 turn open). Low power, little torque, surging under light loads and running hot around town. At higher speeds and WOT it gets worse. All jets were replaced with a set of flow tested jets from Runner's Corner. Passages checked etc.
I tried several B carbs with same result.
Here is how I fixed it.
A little history first. When the Model A went out of production Ford or Zenith (not sure which) released a second version of the Zenith B Model B carb for replacement use with the Model A.
It had a #20 venturi vs #22 for B, several jets are smaller and most important they changed the fuel inlet (needle valve assy) from #44 to #55.
1. The 44 was for the Model B which has a fuel pump (note: Float spring must also be used in B carb if you have a fuel pump to control fuel surges).
2. The 55 was for the Model A which as you know has no fuel pump.
The 44 has an .082 inch inlet hole.
The 55 has a .110 inch inlet hole.
Do the math: (Pii R squared) and you will find that the .110 has twice the area on the inlet hole, so it allows twice the gasoline to enter the float bowl when you are not using a fuel pump, the pressure with the pump allows enough gas through the 44 inlet and the float spring helps to prevent the pressure from overloading the float and flooding the float bowl).
It is amazing how much better the car runs with the 55 inlet valve (I do not run a fuel pump) with my B carb. Low end torque is much better, surging is gone and the car will now go 65-70 MPH with ease.
Try it you will like it.
I had trouble finding the 55 inlets so I drilled out a 44. (.110 or #35 drill bit as I remember) The #45 drill is .082 and can be used to check the size on the 44 inlet.
Note: I do not know how drilling will work on the "Grosejet" inlet assemblies (the ones with the 2 balls instead of needle jet). I think the ball may be too small and might slip through the enlarged hole!
I looked at several and was not sure that the ball would drop down far enough to allow drilling all of the brass out of the hole. Maybe you could take the balls out, drill and then replace them.
If you are drilling out a #44 I suggest that you use a drill press and set the bottom stop JUST above the steel needle valve THEN drill it out. If you do not use the stop on the drill press you will strike the needle valve with the flutes on the rotating bit, catch the needle and damaged it.
Note I have not tried drilling out a #44 as I have found a couple of #55’s. Maybe the needle will drop down through the seat hole after drilling
Note: I found some inlets stamped 44 and one 55 (that I borrowed from a friend stamped 55). Some of the 44s were stamped with just 4 so you might find a 55 stamped with just 5.
MikeK
08-08-2010 09:01 AM​
Re: Does your Model B carb-run bad with GAV closed?
Benson, good info! Perhaps the Zenith A carbs could benefit from enlarging the meager pin-seat hole in their float valves too. Now I have to go find one and play with it.
end MikeK comments
SAJ:
In post #13 you mention that you found NO change in EGT when opening up the GAV.
1. I believe that this is because the fuel level in the float bowl is not being maintaned due to the restricted Float valve inlet. I found similar problems also in the past.
2. Another B carb problem caused by the failure to maintain Float level is that when the Power Jet function kicks in at about 75% throttle under high engine loads, the float level is lowered even more by the demand for more fuel. At the same time the fuel level in the main and cap jets is lowered. This makes for even leaner mixture and all of the problems that go with it.
There are few B carbs with the #55 inlets because these were only supplied on the Zenith after production B carbs.
To me, with the flash, the rod babbitt is tin.
I think the rods were tinned all right, as like you said when trying to remove the rest of the thrust, you can see the gray bare metal, the way it should look.
But when the rod was poured, as shown by so many U-Tube videos, they use a strong torch, and mostly a cutting torch, to heat the rod up to temp., and by doing so, they have no Temp. control on the rod and burn the tinning off the rod. That is why the lack of tinning in the middle.
You have to keep the shell at 610 to 640 Temp., If you go over 650 the tinning will burn off the shell.
If you are under 610, the tinning will be sluggish to take the the babbitt pour, and if the shell cools to fast, the babbitt will not stick to the tinning, and you get a cold solder joint.
There is no way to do it that way with out burning the tinning. Your to cold, or to hot always.
So I think with the lack of it showing any tinning in the middle, I think it was burnt off, as it had to go some place.
Herm.
Benson. Great info. I will pull my carb apart and see what the valve is. I cannot remember, since I have had Gross jet, viton and all sorts of things in various carbs to stop leaks. I just turn the fuel off every time now to be safe, since someone said "gravity is our pump and it is turned on all the time". It might have been me that said it in my own head - age is creeping up!
I have no pump, nor helper spring on the float. Just the anti surge baffle in place.
My top speed is above 75 mph. I only did it once and stopped for a plug chop which looked a bit white, so maybe was indeed flow-limited by the float valve. I will certainly investigate more and revert. I am more worried about how rugged these engines are than I was.
Your post will go into my B carb reference folder.
HERM. Great info. once again. And very helpful too, since many are secretive about their pouring processes. I wished I lived near to you, then I could have had the old rods rebabbitted with confidence.
I cannot find any reference to Barcol hardness of Babbitts, and this and a ShoreD are the only testers I have. Do you have any info on Barcol for Babbitts?
Thanks again to you both
SAJ in NZ
