SAJ
I Pulled apart my Touring engine, bought from Snyders 17000 miles ago. The engine is babbitted and was built by Schwalms 5 years ago. I thought it was developing piston slap and suspected no 3 piston, which nipped up without damage at 4000 miles. But No 3 will take a 0.002 inch feeler up the skirt but not a .004. So probably .003 to .0035 clearance and OK.
Rods all plastigauge at .0015 inch and mains the same. But on removing the rods the Babbitt in the rod tops is badly cracked in two and has minor cracks in the other 2. See photos attached. Rod caps look OK to me, and mains have unusual marks but seem OK. The photo plays tricks with the light, and the centre main has dull and shiny patches but is not flaking as it appears in the pic.
Car has a 26% Mitchell O/D and I am paranoid about not lugging it or over advancing it on long steep hills. I change down at 35 mph into 2nd overdrive and max advance is fixed (by a stop on the quadrant) at 29 engine degrees. It never detonates or pings and I retard a notch or two on hard pulls.
So I am very surprised to see the babbitt fatigued and cracked as it is.
Ora Landis advised to retard the timing a bit more but made no other comment via Tom Jordan at Snyders.
I am going to fit Snyders new rods with .020 shells-the type with side thrusts built in.
The shaft is 1.4774, .001 under the 20 thou regrind and using Snyders figures I should get .0025 clearance, but in a trial fit with another club member’s new rods from Snyders I got .0015 with plastigauge. When mine arrive I may have to do a little hand fitting to lose that extra “thou” I guess.
Purpose of this post is to ask opinions on what happened, since I use the car to its max potential but keep revs below 2500 (low gears on hills) and run at 55 mph, with an occasional max of 60.
I have rev counter, temp gauge, thermostat, oil pressure gauge, exhaust gas temp gauge and keep an eye on it all. Engine runs at 140 Deg max despite the 160 deg thermostat. I don’t know why, since the stat tests out at 160 deg on the bench, but my wife’s Tudor with a similar engine that I built up myself runs the same – just below the green on her gauge
I follow other members up hills where they stay in top to 25 mph, where I have changed down and am running light way before them.
My car is 120 thou over bore, Stipe 330 cam, Model B carb, 95 psi Compressions and 10% leakdowns. No sounds or signs of detonation on plugs etc, and just a “slapping” noise on light running on a cold engine, which goes away as it warms. Oil is Mobil 10W-50 V-Twin (higher ZDDP etc) and I did run Mobil1 4t 10W 40 for a short while. Filter is Z9 full-flow.
I hope the thin-wall shells are tougher in the babbitt film than the cast bearings!
This is the same engine whereI posted about a cam train knock. I see nothing wrong here but will replace both timing gears whilst down
Thanks for any advice and hopefully some encouragement for the next 20000 miles.
SAJ in NZ
SAJ in NZ
